Re: transducer cable
How about a little description of what you have, what the problem is. All we know is you apparently want to replace the transducer cable. Transducer cable for what? Bow mounted troller with built in transducer? Depth finder only transducer? Stern mounted transducer? Through hull mounted transducer or shoot through hull. Transducer cables are generally permanently attached and potted along with the transducer. You could certainly try cutting the cable and splicing on a new one but if the cable is shielded, you need to reestablish the shield over the repair.
