Re: tranducer mointed to the hull inside the boat
I mounted one last year.
1. If you have a cored hull you need to cut a hole through the core to the outside layer. DO NOT cut into the outside layer. You need to remove the core material, usually some kind of foam, so the transducer can be mounted directly to the outer layer of the hull. Most/All transducers can't shoot through the core materil.
2. The transducer needs to be mounted parallel to the bottom (ground), not the hull. Most transducers have some type of rotating mounting cup that makes this step easy.
3. The inner surface of the hull should be a smooth as possible. If it is rough use some course sandpaper to knock it down and smooth it out.
4. You should attach the transducer temporarily using some silicon rubber or similar. Take the boat out and make sure it works etc. Nothing worse than permanently attching a transducer and then not have it work. After proper operation is verified use a more permanent glue. In my case I used 3M Marine Adhesive Sealant - Fast Cure 5200. Don't know if that is the best stuff but I had it left over from replacing the motor in a JetSki and it worked.
