Re: Trailor Lights
You can avoid the "Bad Trailer Ground" problem all together by running another length of wire from the white (ground) wire at the lights back up to the toungs of the trailer and connecting it to the White ground on the trailer side of the harness. This way you do not have to rely on trailer conductivity, ball couplers and severly cuts down on the problem of rust.<br /><br />I have 5 trailers total, and at one time, 3 of them had the same light go out when the brake was applied, all due to bad grounds. I am soon going to run the third wire on all of my trilers to avoid this problem.<br /><br />As far as where to ground on the truck, I would run the wire under the truck and bolt it to the frame. Even if it gets wet, it will not matter as long as the connection itself does not rust up and corrode preventing conductivity. Of course, the further forward on the frame you go, the less likely that you will dip it in saltwater.<br /><br />Good luck to all.<br />Knightgang
