OK:
I need some help here.
My lights are only working on the right side and not the left.
The setup is a four pin connector.
I replaced the four pin connectors on both the truck and the trailer. Still only getting the right side to work and not the left.
Then I tried connecting the brown wire to the red wire of the light (it light up, but still did not blink).
Then I thought the yellow wire must not have been connected right, so I tried to redo that one, but in the process I broke the new connector, so it looks like I will need another one of those
Just to experiment, I connected all of the wires right to each other, without the connectors. Again, the right side worked and the left side did not.
Can anyone give me a step by step fix for this type of problem?
Do I just need to re-wire the whole trailer?
I am guessing the ground is fine, because the right works. Am I right?
Or is the problem on the truck's side with the yellow connecting wire? If it is, how do I fix that?
I have a reese setup on a 2000 toyota tundra.
Any help anyone can give is really appreciated. I wasted alot of time on this today, with NOTHING to show for it.....
Stroth
Stroth
