Re: trailering
knarrman<br />Many years ago I towed a small trailer with a 1300 cc Honda Civic. Guess around 60 hp. Less than 1000 lbs trailer.Four speed manual. As the trailer tucked behind the car, was no problem at 65 mph. Highway mileage without 37 mpg, with small trailer 36 mpg. Air resistance will do more than weight on the interstate. However---going up steep driveway (15% grade)burned out the clutch at 1000 lbs trailer wt. I do not know if an automatic trans will be more forgiving. Be sure to use lower gear uphill, and downhill, a little higher rpm, and a little slower uphill speed would save your trans. The 4 cylinder Toyota motor is bulletproof. Good luck, be happy and enjoy life. Batavier
