TRAILERING PROBLEMS
seadiva
I HAVE A 21' CC WITH A JOHNSON 150, 97 MODEL. I PULL IT WITH A 91 GMC SUBURBAN. I HAVE A YEAR AGO PUT A NEW MOTOR. A 350. I HAVE HAD TO REPLACE THE TRANSMISSION SEVERAL TIMES. IT SEEMS I HAVE PROBLEMS PULLING THIS BOAT, SHOULD THIS VEHICLE PULL WITH OUT A PROBLEM. ITS IN THE SHOP AT THIS TIME, IT LEFT ME STRANDED WITH MY BOAT LAAST WEEK, ITS GETTING REDUN ON WARRANTY. ANYONE ELSE HAVING THE SAME PROBLEM.
22WRF
Re: TRAILERING PROBLEMS
How long are your trips and at what highway speeds?<br /><br />Are you pulling in drive or overdrive?
JB
You may have a Sub that is towing beyond its tow rating.<br /><br />Get a tow rating from your dealer. Make sure it is "as equipped". Compare that to the weight of your trailer, fully loaded.<br /><br />Things that could make your Sub inadequate are: No oil cooler or transmission cooler, too high differential ratio, wrong transmission, towing in OD, towing too fast.<br /><br />Your boat/trailer package could easily weigh over 4,000lb.<br /><br />Pleae do not post in all caps. On the net that is considered shouting, and it is harder to read.
seadiva
Thanks for the input, i may just get another sub.
