Re: Trailer wheel locked in forward free in reverse-help
When (free backing) drum brakes are engaged, the wheel will turn backwards but not forwards. There is a problem with the brakes on that wheel. It could be the brake cylinder is stuck or it could be a mechanical failure of any of several parts. One way to screw up drum brakes is to back into a parking spot while the brakes are wet and leave the tow vehicle/trailer parked that way for a day or two. By backing in, you leave the brakes engaged and two things can happen. One, the shoes can stick to the drums, and two, the master and wheel cylinder bores are exposed to air and can corrode. Always remember to pull forward to release the brakes. Ask me how I know !
<br /><br />As posted above, you have to get the drum off to find the problem.<br /><br />My advice is to seriously consider the replacement sets sold at boat and trailer dealers. You get a pair of pre assembled backing plates with all new shoes, springs, cylinder, etc. for about $140.00. Unbolt the old, bolt on the new, connect the brake lines, bleed, and adjust, and you have new brakes.<br />
<br /><br />BTW: I see the source pictured has raised the price significantly since I replaced mine about a year ago so shop around.
