trailer weights
novicetech
Does any one know of a website that publishes weights of various makes of boat trailers? I have a EQ4315 little dude and I am looking for a weight.
Realgun
Re: trailer weights
Take to truck stop scales. best and easiest way.
rwidman
Re: trailer weights
Originally posted by Realgun:<br /> Take to truck stop scales. best and easiest way.
I agree. A recycling center will also have scales. I paid $5.00.
dajohnson53
Re: trailer weights
Gotta assume you've looked for the manufacturer's tag? Most commercially built trailers have or had one.
Silvertip
Re: trailer weights
Are you looking for the empty weight of the trailer, or its GVWR (gross vehicle weight rating) which is its capacity (weight of trailer and load). Generally the ID plate will provide the GVWR but it won't list the empty weight. Look at the maximum load rating on the tires. That pretty much determines the maximum load anyway.
jlinder
Re: trailer weights
How about looking for the manufacturers website? Lots have posted the manuals for the trailer, and it would give all the weights.
rwidman
Re: trailer weights
Originally posted by Upinsmoke:<br /> Are you looking for the empty weight of the trailer, or its GVWR (gross vehicle weight rating) which is its capacity (weight of trailer and load). Generally the ID plate will provide the GVWR but it won't list the empty weight. Look at the maximum load rating on the tires. That pretty much determines the maximum load anyway.
Mine lists the GVWR and the load capacity. The difference is the weight of the trailer. ;)
