trailer tires
brokeng2
I have a 2005 tracker trailer the tire size on the side of the trailer says
65fx14st. I have never heard of it.
When i ask tire shop and boat dealer they didn't either. I have a 205x14 and seem to be a lot taller. Will the 205x14 work?
roscoe
Re: trailer tires
Make sure you get trailer tires, which are designated by the "ST" on the sidewall.
The other concern is the weight rating of the tire.
What is the GVRating of the trailer? If it is 2000#, then you need tires that are rated for 1000# each, or more to be on the safe side.
If they fit, they will work.
NYBo
Re: trailer tires
That doesn't sound like a valid size designation. What is imprinted on the current tires?
dockwrecker
Re: trailer tires
As long as it's an ST205/14 and clears your fenders I'd bet you'll be fine.
