Re: Trailer tires
Check the load rating on the sidewall of the tire. Multiply that number by 2 (2 tires). The weight of the trailer, boat, motor, fuel, all the gear you haul must be less than that load rating or face a blowout potential. And if you do not faithfully check inflation pressure, any amount less than the rated maximum means the load rating drops accordingly and the potential problem increases accordingly. An if these are not "ST" (Special Trailer) tires, don't bother switching them at all. Get the proper tires.
