Trailer tires
NathanY
The tires on my trailer are size A78-13ST. Can anyone tell me what size that would be in standard size? Example 175/80R13 not saying that is the size, but you know what I mean.
JB
Re: Trailer tires
I think they are the same as ST175-75-13, Nathan.<br /><br />Be sure that the tires carry the ST rating, for Special Trailer.
Oldsaltydog
Re: Trailer tires
Yes, make sure you buy trailer tires, otherwise your trailer will sway too much on car tires.
Richok
Re: Trailer tires
You will want to consider how far you are towing also. Radials run cooler than bias. I had this size on my boat trailer and just replaced with Carlisle radial. Trailer is not handy or I would give you the exact size. It pulls great. Carlisle is a 6ply trailer tire. I also run these on a heavy duty enclosed utility trailer. Pull it over all central U.S. and haven't had a problem yet.
Richok
Re: Trailer tires
I happened to be out at the place I have my boat and looked. It has ST175/80R13. Hope this helps.
