Re: Trailer tires not just car tires?
MarkC,<br />Also, Trailers tires (not car tires) have increased strength in the sidewalls of the tire. (Car tires have all their strength built into the part that contacts the road.) The sidewall strength enables the trailer tires to take more abuse, ie scuffing curbs, hitting underwater debree at the boat ranp, etc. <br />Also, trailer tires are designed to run at higher pressures than car tires. Most say to inflate to 60psi. A lot of problems with blown out trailer tires is due to underinflation. <br />JB is dead-on on the load range stuff. Nothing worse than sitting by the side of the road with a bent, chewed up rim and the former remnants of a tire clinging to it
<br /><br />And of course, dont forget to check the lug each time you go out.<br />Nav
