Re: TRAILER TIRE QUESTIONS
Trailer tires are special tires designed especially tough for trailer duty. <br />Never use a car or truck tire in place of a trailer tire. <br /><br />That size tire with that rating means it is a bias ply. I just had that exact tire size crossed over to radial trailer tires and that is 225/75/15 load range "D". It is important to double check your load rating and the tire dealer will do that for you.<br />I put Goodyear Marathon's on my trailer but check with your local dealer. Do not buy older used trailer tires because the dry rot may not be too visable until after they are inflated on your rims. <br />If you replace your tires, you may want to consider putting rv tire covers over your tires if they are sitting outside in the drive way. These covers stop the UV damage from the sun that causes the rubber to crack before its time and you just pull them off before each trip.<br /><br />Hope this helps,<br />Mike.
