carrotsnapper
- Nov 17, 2004
- 243
With all the flap about Carlisle Tires, I did a little of checking and found the following:<br /><br />The guy I talked to said that Carlisle tires in the past have been crummy, which we all have heard. He did say that the new tires have been a lot better. He gave me some trailer tire facts.<br /><br />Trailer tires are designed for use on trailers only, not for the loads applied to or the traction required by drive or steering axles.<br /><br />Always inflate to the maximum inflation indicated on the sidewall. Underinflation is the #1 cause of trailer tire failure.<br /><br />If a tire fails on a tandem axle, you should replace both tires on that side. The remaining tire was likely subjected to excessive loading.<br /><br />All "ST" tires have a maximum speed rating of 65 mph.<br /><br />Time and elements weaken a trailer tire. In about 3 years roughly one third of the tire's strength is gone. Three to five years is the projected life of a normal trailer tire.<br /><br />The mileage expectation of a trailer tire would be 5000 to 12000 miles.<br /><br />ST tires feature materials and construction to meet the higher load requirements and demands of trailering.<br /><br />Use tire covers to protect the tires from direct sunlight. for long term storage, put the trailer on blocks to take the weight off the tires, lower the air pressure and cover tires as stated above.<br /><br />Clean tires using a mild soap and water. Do not use tire-care products containing alcohol or petroleum distillates.<br /><br />This info was found at the following url:<br /> http://www.knowledgecenter.net/recFitTech/TrailerTireUpdate.shtml <br /><br />I found this informative. I realize that they are in the business of selling tires and will do all they can to sell more. Good luck. Mark.
