Re: trailer spring question
tgodiver,<br /> Been there,done that.
Sure,if you can find a set of the correct measurment between eye's. Measure carefully between eye(or bolt)centers.Using the same spring type as original is preferred but closed eye's are ok as long as you get the correct capacity.Take a look at NorthernTool.com.Be careful selecting springs,most are rated(weight capacity) as pairs(2),instead of each.Good luck.
