Trailer Shackle repair/Fix Pics
TJS
This trailer is for my Jet boat but this will apply to other leaf sprind trailers as well. It tows much better as well after the fix.
Ok this trailer was home made many years ago I guess. It was made by "Hack and Butch Inc." trailers. I guess they did not have a drill, they torched all the holes and did not have a band saw either as you can see by the torch cut parts.
The shackle bolts were 1/2" and not 9/16" with washers taking up as spacers and it was just sloppy. Suprisingly the spring eye bushings were good. So I got all new spring eye bolts and went to work. I cut the half made shackle mount and made some parts and bushing to box it in and spacers and the outside shackle to in order to align the spring pack. The bushing welded to the plate will take up the slop in the torch burnt hole instead of a drill. Much better now.
TJS
Re: Trailer Shackle repair/Fix Pics
Pics cont.
T.J.
89 Baja 190es --project
Nordic Jet boat BBC EFI 8-71 (700+HP)
redone4x4
wow those are some nice lookin welds!
Silvertip
Agree on the welds -- nice job. One thing I noticed however is that some of the nuts appear to be standard but others are self locking (nylocks). I suggest that nylocks be used in all of the spring hanger attachments.
TJS
The nuts on the bottom of the spring came with the shackle bolt kit (special shank bolts for shackles). I have red locktite on them. They are also torqued to what the bolt kit states. They are fine thread 9/16 specifically for shackles. I did not have any nylon fine thread lock nuts on me so I just used the ones that came with the kit.
T.J.
