shelbydriver
- Dec 13, 2002
- 173
Hi, Just put in two 3500 lb axles with 4 leaf springs. There is a equalizer between the two leaf springs. I somehow look at it and the rear eye of the eye to eye springs is hooked up below the eye with a shackle. I have seen other trailers and it looks like it should be above the eye of the Eq? Is this going to be a problem? Also the front springs my friend said I put in backwards as there is a steel strap binding them together and it is in the front instead of the back. is there a problem with that? Any help appeciated. Wheaticat@aol.com
