Trailer Parts
Olde Merc
I have an older Shoreland'r trailer (probably mid to late 80's) that looks to be designed to carry smaller 14'-16' boats. The trailer is galvanized steel and is still in excellent condition. However, last season when I did the wheel bearings I noticed my wheel seals are not in great shape, but were still good enough for one more season. Additionally, I tried to install some bearing buddies, but I couldn't find ones that would fit my hub (the hub was pretty close to 2", but a 2" bearing buddy would not fit). <br /><br />I don't think any of the local boat shops sell ShoreLand'r trailers. Where can I get parts for this trailer like the axle seals and bearing buddies? Canadian Tire has a wide variety of generic trailer parts, but I have know idea if they would work on mine since I don't know any specs on the trailer. How can I identify my trailer by model and year? I would like to put bearing buddies and new seals before on the trailer so I don't have to repack the bearings every season. <br /><br />Thanks for any input.
Northern Eclipse
Re: Trailer Parts
Old merc, I had a old shorelander 1984 model with my old boat, I ran into the same problems, I took one of the grease seals to a autoparts supply here in Oakville the guy behind the counter measured the seal with a mic. then was able to referance the size to a part number, bingo they were in stock and fit perfect.The bearing buddies I bought a bit oversized and had a buddy who worked in a machine shop machine them to fit the hubs.
Olde Merc
Re: Trailer Parts
Thanks for the replies. I wish I knew the year and model of the trailer i have. But I guess the only way I will be able to get parts is to measure the seals and hubs more accurately and see if a parts store can get them. Hopefully I can find some bearing buddies that work, since I don't know a machinist! Interestingly enough, I saw a 1.98" bearing buddy kit at Canadian Tire the other day. I am going to remeasure my hub with more accuracy and hopefully this will be my size. The 2" was so close to fitting, I couldn't believe it wouldn't seat.<br /><br />My trailer and boat are stored 80 miles from where I live. I was hoping to buy the parts and redo the bearing before I brought it home, but I guess I will have to wait until I get home now so that I can take parts measurements before I go to the store.
wajajaja
Re: Trailer Parts
uh, don"t they have auto parts store near the lake. take the hub off at the lake and take it to the parts store? beats being towed half way home?
wajajaja
Re: Trailer Parts
or buy all three bearing sets/seals and takem with you and return what you dont need?
Olde Merc
Re: Trailer Parts
I could do that, but the area I have the boat stored in doesn't have any good parts stores. That's why I wanted to buy the parts before hand. If worse comes to worse, I can just repack the bearings before I tow the trailer, and re-use my old seals until I get home. Then when I get home I can disassemble again, and go to the parts stores to get my parts. I just was hoping to avoid doing the wheel bearings twice in a row. I hate repacking wheel bearings, which is another reason why I want to get bearing buddies. It's bad enough all three of my vehicles also have wheel bearings that need to be repacked on top of my boat trailer.
wezie
Re: Trailer Parts
Shorelander has a web site.<br />Not very useful and very tedious,<br />You might be able to contact them and get some info; give it a try. Let me know if you have any luck.<br />Don't know if this is relevant, but buddy bearings are intended to be hammered in very tight. I use an 8" 4x4, hammering on the end grain, to seat them.
Boatist
Re: Trailer Parts
Olde Merc<br />The Bearings and seal will all have number stamp into them and any decent bearing supply house will be able to find a replacement.
dakotashooter2
Re: Trailer Parts
Take a file and slightly camfer the bearing buddies and the end of the hubs to allow them to get started then knock them in with a 2x4 and mallet. You want them REAL tight or they may spin off like a couple of mine have done.
Olde Merc
Re: Trailer Parts
Thanks for all the information posted. I checked the Shoreland'r website, and it didn't seem to have any information on older trailers. <br /><br />I am sure the bearing buddies I bought were 2" in size, not 1.98". These ones would not fit, no matter how hard I tried to pound them in with a block of wood and my biggest ball peen hammer. These bearing buddies were actually a cheap no-name, so maybe that's part of the reason why they wouldn't fit. <br /><br />When I disasemmble the hubs, I will look for the part numbers. At least with a part number I can be somewhat sure that I am getting the right parts.<br /><br />Thanks for the tip on the chamfering the bearing buddies. I will try that if they won't fit otherwise.
Re: Trailer Parts
I know on my trailer the plate/sticker is real hard to read after all these years so I just took the information w/serial number off the registration that I have to carrey a copy of in the boat. A quick trip to ez-loaders web site and I had a dealer number to call.<br /><br />Just a thought.
