trailer lights
jodeye
I have installed new lights on my trailer now when my truck lights are turned on no trailer lights work when truck lights turned off the trailer lights work, any ideas?
Pony
Re: trailer lights
I would make sure all your grounds are good and clean (One at the tongue and then one at each light on the trailer.) Remember you wont get a good ground through rust or paint......the 2 or 3 times I have replaced all my lights and wiring, making good grunds was difficult because of that.<br /><br />I would check that first and then proceed from there.
Re: trailer lights
Pony is Right on the Money,........<br /><br />Just for a Test,....<br />Attach 1 end of your Jumper Cables to to your Tow unit Frame,...... And the other end to the Trailer Frame,......<br />Make SURE it's a Metal to Metal connection......<br /><br />I'll Bet'ca your lights will Work,........ Perfectly............ ;) <br /><br />Good luck......
Silvertip
Re: trailer lights
If you turn OFF the truck lights, how can the trailer lights turn ON? No power -- no lights. If you are talking about BRAKE lights, that would be possible and is likely a ground problem as point out. The white wire from the trailer plug must be firmly attached to the trailer frame. Each trailer light must also have a good solid/clean ground to the trailer frame. The bolts that hold the light to the trailer make that connection.
tommays
Re: trailer lights
<br /><br />look out for that white ground wire it causes a lot of problems<br /><br />tommays
