Re: Trailer lights
Sorry, guess I wasn't clear enough when I said<br />
Check ground connection between each light and trailer frame
I meant the ground from each light to the trailer frame, not between lights.<br /><br />
Mike64 - the trailer running lights
can work in the absence of a good ground at the trailer lights because the current will flow through the vehicle's brake/turn filaments back to the vehicle ground. (The brake/turn lights don't light up then because the voltage is dropped across the higher resistance of the running light filaments.) But when the vehicle brake filaments are energized the voltage applied keeps the trailer light current from flowing through the vehicle brake filaments and all the trailer lights go out. You've got those classic symptoms. If this is all Greek to you, don't worry about how it works, just go make sure each light has a good ground to the trailer frame, like
jajeeper said in his first post above.<br /><br />As
78FOURWINNS says, if you've only got 2 wires coming out of the light, the ground is likely the mounting stud. If there're 3 wires then one of them is the ground and the mounting studs may not be connected to anything in the light electrically, but you can still put the ring lug from the ground wire on the stud. Just be sure that the ground lug makes good contact to bare metal on the trailer.<br /><br />If your trailer lights are mounted on the tilting portion of your trailer, then down the road if your trailer lights start to behave intermittently, you might have to put a ground strap between the tilting and non-tilting parts to maintain the ground.<br /><br />Good luck.
