bigman,<br /><br />If you have seperate turn and brake lights, which I suspect you do, you will need an adapter for six wire to four.<br /><br />I believe U Haul offers them.
I would first check with a Honda Dealer to see if there is a kit that is available that allows you to simply plug in an accessory trailer wiring harness. <br />If no such thing is available then you will need to buy a module that allows the turn signals to work on your trailer with the brakes light on, because they usually do not have separate turn sinals and brake lights like your car does.<br /><br />Mike.
