My trailer lights will work if the vehicle is off. When the vehicle is running and you hit the brakes the lights completly go off. When you use the turn signal the correct turn signal works but the other pulses at the same time. I am being told that it is probably the ground. They are grounded to the trailer. I need to replace the plug which I am doing tonight. Do you all think it is just the groud and the plug? Thanks for the help.
