Re: trailer lights blowing fuses
Sorry to see that your problem persists. But I think you've done good toward finding the root cause by determining when the lights
do work. Blowing the dedicated 20A fuse has to be caused by a short circuit. A rusty trailer isn't a short, nor is a long length of wire (presuming of course that the new wiring you installed isn't pinched or cut somewhere along its length by the rusty trailer).<br /><br />So you've just got to figure out the real difference between the lights working OK and the fuse blowing. When you said:<br /><br />
I took a strip of metal that had holes in it and connected the lights and ground to it and then hooked it up to the van. Everything checked out great, no blown fuses.
What
exactly did you do? Sounds like you mounted
both rear trailer light assemblies onto the metal strip, right? Was this with or without the wiring harness? Did you hook it up to the van using the wiring harness and trailer connector? If the brake lights didn't blow the fuse when mounted to the metal strip with the wiring harness connected and going through the trailer connector, then the only differences would be running the harness and mounting the lights, so you'd want to check the harness for spots where it might be pinched/shorted to the frame, and the mounting of the lights for any distorting or pinching of wires.<br /><br />Carefully looking at the difference(s) between when the lights worked without blowing the fuse and when the fuse blew can point to the cause.<br /><br />If you have a multimeter you can "brute force" the issue by measuring resistance between the green and white wires at the trailer connector, and between the yellow and white wires at the trailer connector
with all the brake/turn bulbs removed. As
voxmorgan says, you should see an open circuit (very high resistance). A few ohms to near zero indicates a short somewhere along whichever wire (green or yellow) reads low. IMHO you need not disconnect the boat batteries since they have no connection to the trailer. The white ground wire should connect to the female receptacle on the trailer connector, the green (right turn/stop) wire to the farthest (1st) male pin, and the yellow (left turn/stop)to the 2nd male pin, with the male pin closest to the female being the brown (running lights) wire. Good luck, keep us posted.
