Re: Trailer Jack
actually, with a tandem axle these work great. ride your good tire on top and the flat is off the ground. very quick and no climbing under the trailer to position a jack on the frame. they also work great on grass or most soft surfaces unlike lots of jacks.
Interesting... On my tandem axle, when an axle rises, the equalizer moves, causing the other axle on the same side to lower, such as going over a speed bump. That way, both tires tend to maintain contact with the ground. If that didn't happen and one tire came off the ground, the one still in contact with the ground would be severely overloaded.
Just saying.... Your trailer may be set up different, but every tandem with an equalizer on the suspension will work this way. Perhaps the torsion axles are different, but I suspect not, keeping both tires on one side in contact with the ground independant of each other.
