Good evening folks. I got some new tires for the boat trailer today (Maxxis M8008 185-80/13), and while I had them off, I figured I would go ahead and inspect and repack the bearings, and replace the seal. Everything looked good, so I repacked the inner bearing and replaced the seal. While tapping the seal in, it went past flush with the surface of the hub. I thought about it a couple of minutes, then I decided to go ahead and finish putting it together. It is approx 1/8-3/16" inside the hub face. Do I need to take it back off and bring the seal back flush with the hub, or can I leave it like it is?
