Trailer hub replacement
Mikek89
I would like to switch from a drum brake hub to an idler hub and I’m wondering if the mounting bracket attached to the axel that the drum was bolted too has any structural significance or can I disregard it and switch to an idler hub. Thanks for the help
ahicks
That plate the backing plate fastens to should not interfere when the backing plate is removed and used with just a hub (no drum).
GA_Boater
Welcome aboard.
The square backing plate mount won't interfere. In fact many axles are on the road with the mounting plate without a brake drum or disk if brakes aren't required.
The question is why are you removing the brakes?
