trailer hitch weight
Hawaiian
The hitch on my trailer (ez-loader single axle)takes two people to lift. The boat is a 16' Boston Whaler Dauntless that weighs around 2200 lbs loaded. Does anyone know approximately what the hitch weight should be?
JB
Re: trailer hitch weight
Hello, Perry.<br /><br />I believe that 7-10% is standard. That would be 150 to 220lb.<br /><br />Your tow vehicle needs to be rated for towing not less than 2500lb and for 300lb on the hitch.<br /><br />A bathroom scale under your jack should give you a good indication of tongue weight. <br /><br />Good luck. :)
Hawaiian
Thanks for the replies folks. I will use a scale to weigh it and make a change accordingly.
BassMan283
Whoa! JB, you're right. What the heck am I thinking about? Oh well.
