Re: Trailer bunks
What's the rest of your setup? Does it have side guides? What kind of clip holds the bow eye when the boat is loaded if there's no winch? <br /><br />My trailer has a winch, but frankly I never use it and have considered eliminating it if I could come up with a good way to get a tight hook on that bow eye. I set the trailer deep enough in the water to simply idle it onto the trailer until the bow taps the front roller by the winch, leave it idling in gear, then I walk up in the the bow and lean over the front to hook the winch and give it 2 clicks to snug it up (don't even need to get out of the boat.) Now put the boat in neutral and shut it down, tilt the motor up, (bear in mind the boat is still floating, just hooked at the front eye) and pull it outta the water. The side guides only allow about 1/4 to 1/2 inch of side to side movement of the back of the boat, so when the truck pulls the trailer/boat out of the water, it always settles down onto the bunks perfectly centered. When unloading, I back down until the boat is floating, unhook the winch, and back off. So basically my boat never slides on the bunks.<br /><br />If a ramp doesn't permit drive-on loading, I can do the same by simply floating the boat all the way onto the trailer with a rope. Have yet to find a ramp where I can't get my trailer sunk deep enough to use this method, though occasionally the back tires of my truck are getting a little wet, and this method elminates all cranking and "sticky bunk" problems.
