Re: Trailer Bunks
Try aluminum bunks! They are fairly new to the industry, but work well.<br /><br />
http://www.greatlakestrailers.com/
<br />I went to your site, and could not find any mention of aluminum bunks (only mention of Michigan hardwoods), only an advertisement for a trailer manufacturer (how are you getting this publicity past the "MODS"?
). It seems to me aluminum bunkls would be very expensive.<br />
Lakeman, i konw of the plastic lumber of which you speak and wish i had thought of that 3 weeks ago when i redid my bunks. just a word of advice about this stuff though, because of the way it is pressed together you can put a screw in it but i warn you it will not hold like it would in wood ther will be no compression around the threads to hold it in. You will have to drill throught it and put on a nut and a bolt. other than that it sounds great no rot no need for slicks or you can just carpet over it
I do not know why lag bolts ( they are the first problem, as they are put in with screw guns, usually stripping the threads in the wood) are used to start with on trailer bunks by manufacturers, other than the fact they are cheaper, and save time , as they can be drilled in with a screw gun. I have always drilled holes through, and used 5/16ths carriage bolts, with lockwashers, and nuts on the back, pulling the head into the bunker (below the surface of the carpeted front. This constitutes a few possible problem with the composite's. I have not checked them yet. (1)-Are they soft enough to pull the carriage bolt head below the surface (maybe would have to counter bore a bit to accept the head) ? (2)-Are their dimensions (thickness) beefy enough to have enough strength after counter boring, or pulling the head below the surface (actually, if the carpet was applied after installation, they would not have to be countersunk, as the carpet would go over the heads). (3)-are they too brittle to use, giving enough strength between mounting points (when used on decks, they are supported every 16/24 inches). (4)-How expensive are they? (5)- When covered with carpeting (holding in the water) will they rot as fast as or faster than treated lumber?
