Hi to all,<br /><br />After two years, finally found the exact flatboat I have been looking for. Tims custom 16x54 little wider, longer and higher sides than the flat I have now plus its a welded flat.<br /><br />The two bunk boards that are under the boat now are bare and are 2x4 about 6'long. Without the engine the flatboat pivots on the front of the boards. When the transon is straped down it lays flat but I'm thinking there is tremendous pressure under the boat on the area by the front of the boards. I'm planing on replacing them with 8' long boards so they will rest on the entire board. <br /><br />The main question, Most boards are covered with carpet. I'm thinking of covering them with a codex material. (a type of plastic wall protective covering, very durable and it can be heated and bent down the sides of the wood and attached. The boat should slide off the trailer easier, but I'm concerned that when I am driving the boat up the trailer and then kill the engine, that maybe it will slide off again before I can attached the front trailer wench strap.? <br /><br />Any opinions would be appreciated.<br /><br />I just ordered a CMC power trim kit from Iboats it should get here tomm. My 48 spl had the power assist piston that has long lost its assist. In fact now it is a pain in the butt.<br /><br />Sincerly,<br />Beck
