edgutgesell
- Jul 18, 2004
- 144
I have a mid 80's EZ Loader tandom trailer with surge drum brakes. I recently had a wheel lock going forward but it would roll backward. I pulled the wheel and drum as a unit by removing the bearing buddy, cotter pin and nut. The cause of the wheel lock was the front brake lining had ripped off and was jamming going forward. The brake shoes, springs, backer plates, etc. were very corroded so I decided to replace all four brake assemblies with new brake assemblies. I also decided to replace all of the brake lines with new stainless steel lines. <br /><br />The backer plates do not have bolts and nuts securing them to the axles. Instead of bolts, there are studs that are welded to the backer plates and nuts on the studs secure the backer plates to the axle. Three of the four bolts came loose with a breaker bar after soaking with PB Blaster for hours. Is there a better penetrating oil?? I have heard that "Fluid Film" was very good. The fourth nut wouldn't budge even with heat because I could not get a socket completely on the 11/16th nut. I finally bought a "nut buster" to split the nut. This worked but the job to replace a single brake assembly took much too long to accomplish and my arms and hands will probably be scarred for life.<br /><br />My question is:<br /><br />What can I use to speed up removal of the corroded brake backer plates from the axles? I don't have an acetylene cutting torch, but that would be my first choice if I knew how to use one. I do have a reciprocating saw, but I will be doing the brakes and line replacement with the boat on the trailer. My reciprocating saw may be too large to handle between the boat and trailer axle. Has anyone used a reciprocating saw for this job? Will a grinder work? What would you use?? <br /><br />As always, your responses are greatly appreciated!!!
