Hi all:
I have an EZ Loader trailer for my 19' boat. I just replaced the rear tail/brake light assemblies because the others wore out. They worked fine before the red plastic lens came apart. Now mind you, this is a fairly simple remove and replace operation. The wiring can only go on one way, so they are not hooked up backwards. ..at least I don't think..
I believe the grounds are hooked up right. With headlights/running lights on, the tail lights come on just fine. When a turn signal or hazards are selected, the rears blink as well except opposite to the vehicle ones. Also, they blink off instead of just increasing the brightness (second filament) with their blink. Also when brakes are applied with running lights on, the rears go out and stay out as long as brake lights are on.
Okay, I'm usually no dummy, but I'm missing something pretty elementary here, I think.
What do you all think????
