Re: Trailer Bearings
Pretty basic mechanics replacing/repacking wheel bearings.
Loosen lug nuts
jack up wheel
remove lug nuts
using a flat screwdriver remove hub center cap
using side dikes or needle nose pliers remove cotter pin
loosen and remove axle nut, (notice it was not real tight)
remove outer wheel bearing
replace axle nut putting it on about 3-5 turns
in a slide hammer type motion pull the hub towards your chest hitting the inner bearing on the axle nut. It should pop out with the wheel seal.
remove axle nut again
pack new bearings with grease
place inner bearing inside race in the inside of the hub.
lightly tap new wheel seal into place
put hub back on axle
put outer wheel bearing in hub
replace washer I for got to tell you to remove
replace axle nut do not over tighten
line up castle nut with hole in axle
put new cotter pin in hole and bend it over the tip of axle
replace center cap ( i recommend using Bearing Buddies)
put wheel back on
hand tighten lug nuts
lower jack
using lug wrench, tighten lug nuts to spec
Did I forget anything?
