Re: trailer bearing question
Tires tend to get pretty warm during the summer. My test for hub heat, which is an entirely different thing, is to firs feel the tire and then feel the hub. If they are about the same (and I can hold my hand on either) I don't worry about it.<br /><br />One thing though, the heat liberated by braking won't heat up the tire, it disapates quickly from the wheel. Braking may heat up the hub enough that you'll notice it but the heat bleeds off quickly. I say that as a person who checks the wheels at every stop. When I pull into a rest area off of an interstate I tend to get on the brakes pretty hard because I do not like to slow down while still in traffic. So I reserve my braking for the access road to the rest areas. Even with that heavy braking (bringing down our typical 7,000 pounds or so load from 60 to 20 in a short distance) I can still put my hand on the hub if everything is OK.<br /><br />Thom
