tracker wireing
marcengillb
Just bought a used tracker pro 18 ,someone moved the troling battery to the front,I need to put it back in the back,any idea on how to run the wires from the back to the front?
Silvertip
Re: tracker wireing
Should be a channel(also called a cable conduit) you can run the wires through. Use 6 gauge wire or there will be too much drop due to the length of the cable.
