Tracker Pro guide v 16 rack and pinion steering problem.
Status
Not open for further replies.
biggamefish
I have a tracker boat just got done cussing and swearing at it while i was taking it apart. I diconnected the steering form the motor and the motor turns nicely. I took the peice out from under the wheel and the wheel moves fine so it has to be some part of the cable. That out of the way I tried to take the the sleeve out of the motor to see if I could relube/clean that but I couldn't get it to slide out. So I couldn't relube it. I grab ahold of the cable i can slide the outer sleeve back and forth no problem but the inner one works hard. When I do get it to move I get a brown slim/grease that come out on the inner and outer sleeve.
Is there an easy way to remove these sleeves it seems I have to move the engine over to ge the sleeve all the way out. The boat is only and 07 so I find it hard to believe the cable is garbage. Any help would be apprecaited.
BassBen
Hi, Just curious. Nobody seems to reply to you. Did you finally get your problem solved? If so, how?
Status
