Tracker Marine Trailer
Defiant
Hey guy's doe's anyone have any info on a 1986 Tracker Marine Trailer for a 16 ft boat all I can make out on the tag is the year and Jlm Industrie's trying to fiqure out the GVWR .The trailer was given to me the other day and is in great shape so might use it if I can find a decent boat for it .
It's a single axle trailer with 13 inch tire's on it any help would be appreciated
spacerust
Re: Tracker Marine Trailer
i had the same year trailer. i'll look at my paperwork and then post the info you need.
Silvertip
To get in the ballpark, check the sidewall of the tire for the load rating and multiply by 2. For example, if the tires have a max load capacity of 1375 lbs each you have a GVWR of roughly 2750 pounds. That capacity however is not what the trailer will haul. You need to subtract the trailer weight to determine what the actual "load capacity" is. Load capacity is the weight of the boat and everything in or on it. If the tires are not original, you have no idea what the actual GVWR is. But again, you can count spring leafs and then check some on-line catalogs to determine spring rate which will also get you close.
Defiant
Thank's for the reply's The trailer came with car tire's on it so I cant go by the tire's I think it has 3 leaf spring's but not sure can check if needed .
Spacerust that would be a great help if you could post the trailer info
Thanks
Silvertip
You can pull the wheel and hub assembly and measure the inner and outer wheel bearings. If the spindle has 1-1/16 inner and outer bearings, it is a 2000# axle. If it has 1-1/16 outer and 1-3/8 inner bearing it is a 3500# axle. Note that its AXLE rating. But generally if that capacity axle is installed, the trailer is sprung for it as well. I suspect with three leafs you have a 2000 - 2200 pound axle.
Defiant
Thanks silvertip it doe's have the 1 1/16 inner and outer bearing's so guess that answer's alot of my question gonna install some good trailer tire's and try and find a decent boat for or .The trailer is in good shape hate to let it just rust when it can be used
sbulla
Sounds like you have the same trailer as I got with the '87 Tracker Tournament V17 purchase I made last year. Sorry, but the tag on my trailer is missing also.
Sonny
Defiant
Yes Sbulla the trailer looks alomst I dentical but mine is painted black from the factory other then that it look's like a mirror image
