Re: Towing XL700 on the water
well truth be told if the impeller is just in the correct place towing over an idle can force water up the cooling hose and flood the engine,, so remove your plugs crank over the engine and pump the water out,, then pour a few ounces of auto trans fluid in each carb and in each plug hole,, that will mix with the water,, and lube the rings etc,, use a old towel to reduce the mess and crank all the out it will turn pepto bismol pink when it mixes with water,, but it will get it out,, then use some starting fluid in the cylinders finger tighten the plugs, keep cranking it over, removing the plugs clean them with the starting fluid and repeat till it starts to try and run,, then it will gradually run and smoke like hell, but eventually it will run and you should run it on the hose a while to warm up the engine and drive out all the moisture.
