Towing with Power Tilt and Trim
lso254
I have a 16' Trihull with an 85 HP outboard. I just installed a power tilt and trim unit. I also added the trailering bracket which allows the motor to rest on it while in the down position. It is a Force moter, do I need a transom saver or is it safe towing this way?
Ranger354
Re: Towing with Power Tilt and Trim
I believe that the trailer bracket that you mention is what we call a transom saver. Sounds like the same thing to me. It fits between the back of the trailer and the skeg of the motor.
lso254
no, this goes in the slots that I used to have a manual pin for. nothing on the skeg
JB
Get a transom saver, Beginner. It will also save your T'n'T and your skeg.<br /><br />Red sky at night. . .<br />JB :)
lso254
my boat hangs over the trailer by about a foot, don't know if a transom saver will attach to the trailer? any suggestions?
dihwp734
Cabela's sells one that works with that situation. I believe it is about $40.
