Re: Towing with a Land Rover Discovery?
Hey Snailman!<br /><br />You'll like to truck, but do a search online to find the OEM harness, it will save you about $100. I think you can pick it up from Roverconnection.com<br /><br />Also, install is a snap. All you REALLY need is a screwdriver and a big wrench to install the mounting tab to the back of the truck. You simply remove the (4) screws on the passenger side tail lamp and the kit simply plugs in. It should take you no more than 15 minutes to install and you can't screw it up. The only problem you might run into is moutning the tab on the trailer hitch bolts. For that, I paid the local mechanic $20 to buzz it on for me. <br /><br />The Mariah, it's great! It's a bit older (96) but was made by the original Mariah factory, not the new one so quality is quite a bit higher. Now if I can only find the correct prop for this pig, we'll be in business!!<br /><br />Check out the Landrvoer site I mentioned before, my SN is 02Disco2 and I am a moderator. Very good knowledge base escpecially if you are new to the Land Rover community (it will save you TONS of $$ and headaches down the road).<br /><br />Enjoy!<br /><br />Ryan
