- May 19, 2001
- 26,052
JB had done a fantastic job of getting the new boaters started and I thought this would go right along with his comments. These are just a few guidelines to insure we can get our boats from point A to point B safely.<br /><br />BEFORE YOU TOW<br /><br />Inspect the vehicle and trailer to see they are roadworthy. Check the trailer springs, bearings and brakes (if equipped) for good working condition.<br /><br />Inspect your tires checking the recommended inflation. Trailer tires are normally higher than passenger car tires in PSI.<br /><br />Ensure the ball and coupling socket match and they are the same size. Check your safety cables and chains. Cross them beneath the trailer tounge before you hook them. Check your lights too. <br /><br />Make sur your boat is tied down!!!<br /><br />TONGUE WEIGHT<br /><br />The tongue weight should be about 10-15% of the total weight (Gross trailer weight) to insure good towing characteristics. However slightly light will work but never go below 7% of the Grass trailer weight. This would create a wagging (snake like) situation.<br /><br />WHAT YOU NEED TO KNOW ABOUT DRIVING<br /><br />Allow for extra room while entering traffic based on your new length and width.<br /><br />Allow for greater stopping distances!!<br /><br />Use a lower gear while going down steep hills to save on the brakes.<br /><br />If the trailer starts to sway or "wag" like a dogs tail avoid hitting your brakes. Let up on the accelerator.<br /><br />If you attempt to pass anyone it will take longer so keep that in mind for your sight distances.<br /><br />Be advised that cross winds and passing vehicles can effect your handling.<br /><br />Steer and brake smoothly to avoid swaying the trailer.<br /><br />WIRING<br /><br />4 way plug through 7 way plugs all have the basic same color patterns.<br /><br />GREEN Right turn and brakes<br /><br />YELLOW Left turn and brakes<br /><br />BROWN Marker lights/running lights<br /><br />WHITE Ground<br /><br />RED Auxilliary power (winches ect)<br /><br />BLUE Electric brakes<br /><br />Purple Back up lights<br /><br />If your vehicle has Europeon Standard turn signals (AMBER) then you can purchase a converter at an auto parts store to accomodate the wiring change. Standard T connectors are now sold for must vehicles which is like "plug and play".<br /><br /><br />Best of luck, it's not brain surgery just good old common sense. ANY questions just ask them. <br /><br />Bob
