Towing Holiday 200 with Mazda B4000
pderuytter
Hello. Recently bought a 1986 Cadorette Holiday 200. I drive a 2007 4x4 Mazda B4000. Should I have any trouble launching and retrieving the boat? Some people are saying that my truck won't be able to pull it from the water. Figured I would get some experienced opinions from here. Thanks!!
Peter
haulnazz15
From a brief internet search, I think you'll be right at the limit. You should have a 207HP V6 and 5600lbs towing capacity, but I'd verify that if I were you. Your rig w/trailer will probably be right around that 5Klbs mark, so you'd be at the max. I wouldn't want to be towing long distances (200+ miles) with it, but it will probably be sufficient for shorter trips.
nickcunn
I would stay away from steep ramps. Depending on where you are there should be shallower ramps to use.
oldjeep
What's your basis for that statement? He has 4WD, and crawling up a steep ramp shouldn't be an issue.
Only issue I could see is the ability to put that power and 4wd to the ground in what is a very light little truck. Steep ramp means very little tongue weight helping out. I've got a sub 3000lb jeep that is capable of pulling just about anything that isn't heavy enough to drag it backwards.
haulnazz15
I can see wheel spin being an issue. My FIL uses an old wrangler to pull the 19' runabout out of the water on a regular ramp (not shallow or steep) and it can get some wheel spin/hop on occasion. The main problem is the wheelbase being so short.
