Re: Towing Gear
Depends on the conditions. On flat, level roads, you can tow in D. If you're pulling hills, use 3. In either case, you need a good transmission cooler, if one's not already installed. Let the vehicle be your guide. If it's frequently shifting between OD and 3, then shift down. If you're towing and it's not shifting, then you don't have a problem.
You could also consult your owner's manual to see what it says, but if the thing's not constantly hunting for the right gear in D, then you'll be OK.
