tow fuse for 1997 Chev 1500 Express Van
wgander
Anyone know if there's a separate fuse for the factory installed trailer wiring harness?<br />I've been having problems with the trailer lighting. I replaced it and have the same problems, such as dim turn signals when the running lights are on. Last night, the fuse for the instrument panel/running lights blew - I replaced it. I'm convinced it's not the trailer wiring. I replaced the short 4 wire harness on the van today and one of those plug in light checkers didn't show any operating lights. I disconnected that harness and used a 12 volt continuity light on the factory harness. With the clip to the ground wire, I didn't get a continuity light when I touched the probe to any of the other bared wires (run,turn, brake). The owners manual doesn't mention anything about a separate fuse and none of the fuses listed in the operators manual or fuse panel indicate they'd control the trailer wiring.<br />The van lights work OK.
D
DJ
Guest
Re: tow fuse for 1997 Chev 1500 Express Van
Bill,<br /><br />Are you sure that vehicle has a factory harness?<br /><br />You will not get continuity on the brake, turn wires unless the key is on and they are activated.<br /><br />How is your TRAILER harness grounded?
wgander
Yes, it's a factory harness. I bought the van new from the dealer with the factory tow package already installed. The wire harness was tucked under the frame in the rear, all nicely labeled, when I first bought it and added the 4 wire harness for my trailer. (The factory harness is just wire - no connections on the end.) All the lights have worked for several years.<br />When I used the harness connection light checker, and then the continuity probe, I had the key on and signals/hazard light activated.<br />The harness from the vehicle to the trailer connection is grounded to the vehicle trailer wiring harness; the trailer lights are grounded to the trailer and the 4 wire trailer harness also has a ground connection to the vehicle.<br />But, I donm't think the trailer's the problem, anway, since the continuity light never gave me an indication of power on the vehicle trailer wiring harness.
Richok
Bill you should have a fuse for the trailer harness. I think that vehicle has an underhood fuse/relay box.
