Lcp-angler
- Jun 29, 2016
- 22
Hi guys this is only my second post.
I do alot more reading than posting but I have a tough decision to make and could use some help.
I currently have a 1984 Mark Twain 210sfo with a Johnson 150 outboard.
I love the setup of it runs strong but the problem is that the transom and stringers are shot like really really shot.
now I have a 1986 Larson that I could trade for trading my quad the Larson has a Merc one outdrive and a 305 small block.
the boat overall is in much better shape the outside is nice and the interior is much nicer than the other boat.
the cabin has all been redone has all updated electronics charging ports sterio sink small closet that was a restroom but was renovated into a closet.
guy showed me photos of it striped he removed everything and replaced it from stringers up in the cabin section.
he also removed all the water sogged foam in that area.
I checked the transom area and from the inside the transom is pretty weak. started to rot but the stringers seem very solid they didn't have any squish to them or feeling of rot .
I was able to reach in an put my hand around the stringers I pushed and pulled on it pretty well seems good.
the Larson also is almost the exact same setup as the Twain the Larson seems to have much more cabin room and much more deck space also seems like a deeper hull.
all electronic work with the exception of the temp gauge in the Twain no gauges work the wiring is a night mare I do not trust it and would have to redo it.
So my decision is do I swap for the Larson and do the transom and the temp gauge (I'm sure I'll find more as I always seem to like to make things fit the way I use them).
Sell the Twain for 1k paid 900$ when I bought it.
Or keep my quad (I don't use much ever rather be catfishing) and my mark Twain and bite the bullet and do the stringers and transom. Thanks for and advice if I need to explain anything better please let me know p.s. the Larson motor has a whole list of new parts.
