I am getting a new trailer for my flatboat and I am concerned about it having torsion axles as standard equipt., the only trailers in my area are magic tilt and they all have the torsion axles on them now.
I have always had leaf springs and straight axles and while the springs need replacing after several years its relatively cheap and easy to do so.
I have serious concerns about torsion axles in that there seams to be nothing holding them on (that I can see) from sliding out of the axle tubes except the spring tension so I see a possible failure point there and since I have no way to inspect or judge the condition of the torsion spring assembly and determine if and when replacement might be needed (if it can even be done) before risking a failure on the road.
what really bothers me is if a spring fails it isn't hard to "rig" it to be able to make it home but if the torsion axle fails I will need a flatbed wrecker at huge cost just to get home.
how indestructible are torsion axles and am I worried about nothing?
also if something goes wrong with it I assume it means you have to change the whole axle as a unit correct?
im an old school guy and if it aint broke and its easy to fix if it does break, then don't change the design. so would I be crazy to take a brand new trailer with torsion axle and convert it back to the leaf spring axle? im guestimating it could do it for around $200
