Re: Torque spec for prop nut
More confusion..................
So we have 2 different systems here; one uses a self locking nut (nylon insert) and a SS tab plate that locks into the prop to keep the nut from coming off.....Merc.
Apparently OMC has a nut also,but it has ears on it and a hole in the propshaft to accept a cotter pin to keep it from coming off.
Now, the difference between the hubs on the props of both engines is the number of splines. Merc uses 15, don't know what OMC uses; doesn't matter.
So from the (proper operation of the) prop standpoint, what difference does the nut torque make to the rubber hub performing properly? Apparently none.
Well the Merc prop nut, with all it's applied torque, isn't going to come off if it were finger tight either, cause it has 2 locking mechanisms to prevent it.
So this translates to me that it doesn't matter what the !@#$%^&*()_+ torque on the nut is!
Then in comes the new plastic hubs at 100 ft-lbs. Guess you are going to have to ECN both mfgr's manuals.
My 2c,
Mark
