Torque Process for upper bearing assy Apha1 Gen 2
Darin113
I have the newer style press fit bearings and gear assy. I a changing the oil seal and short shaft but reusing the existing gear and bearings. Because the bearings were already set with a preload it seems they still have a preload from the original setup after removing the nut to change the seal and short shaft. What would the torque spec be for the nut in this case.
dubs283
There is no torque for the nut. You release the existing preload from the bearing set, reassemble the u-joint assy/drive shaft yoke, retainer ring, seal, bearing set, gear, washer and nut then slowly tighten the nut until you reach the spec of 3-7 lb/in rolling torque for used bearings. You need a dial lb/in torque wrench for the procedure, most commonly used one is 0-15 lb/in wrench
rustybronco
They make beam style in/lb torque wenches that read 15-0-15 also,
rustybronco
Can't use a wrench, needs to be an indicator...
Odd as I've used a beam style to build up plenty of automotive rear axles over the years. I guess all those companies who made them have been scamming us.
Scott06
Ive used the same for ring and pinion changes as well For exact swme rolling torque with no issues. I think Chris indicator is certainly a better and more accurate tool but can get salty for shade tree mechanic
rustybronco
I will agree it's better (ease of reading) but more accurate? I disagree. The dial and accompanying rack and pinion adds additional points where wear 'can' make it less accurate over time. The proof would be in the the amount of calibration required. A beam style shouldn't require adjustment if well constructed.
Scott06
Use whatever you like but typical beam style wrench is +/-7% , dial style is +/- 2% .of course huge difference in cost.
rustybronco
If those numbers are accurate then yes, the dial type is the better option.
M series... "Accuracy of all flat beams is +/- 2% of indicated value from 20% to 100% of accuracy, in both directions."
Just pertains to Sturtevant-Richmond.
Darin113
Do you need a bearing pres to relieve the pre set or can you safely drive the gear out enough with a dead blow hammer?
Rick Stephens
I did mine with the hammer rap to loosen by a few thous. Common trick with Merc mechanics. Great question.
