I have an 86 60hp Johnson (with VRO removed) on my 88 BumbleBee v154 (15' 4"). I replaced all the seals in the lower unit, cleaned the carbs and put new holes.<br /><br />I took it out after fixing it up for about a mouth. It tops off at 25.6 MPH (on GPS). Should it go faster then that?<br /><br />Prop = 13 3/8 x 17<br /><br />Compression<br /><br />Cylinder 1 = 129<br />Cylinder 2 = 122<br />Cylinder 3 = 125
