Re: Too Small for Ocean?
DB, there is some good advice given above, particurlay as regards getting to know your local waters and weather patterns. I have a 16' 6" deep V boat that I take into the Gulf of Mexico. There is a good fishing ground about 30 miles out that I like to hit. However, I pick my days carefully.
- I know the local waters and approaches from the Gulf.
- Weather is obviously important. I make sure that I have at least a good 48 hour weather forecast. Yes, things can change and the forecast can be wrong, but I won't even consider it unless I have a good forecast to start with. Check the forecast again on the weather band before you go ropes-off.
- I make sure that I have a prevailing onshore breeze (as opposed to an offshore breeze). No exceptions.
- Engine Maintenance. I keep my engine in as near-to-perfect condition as I can. I will not venture out if anything is even slightly sketchy. This costs money.
- The fuel system (tank, filter and lines) is critical. It needs to be perfect, which means no old hoses, no bad o-rings, and absolutely positively no water in the fuel.
- The electrical system needs to be in top shape. Not just good enough - but really good. If something is showing signs of corrosion or intermittent operation, then repalce it. The batteries and charging system needs to be reliable. Silicon grease can prevent a lot of worries in salt water.
- Safety gear. Everyone wears life jackets all of the time. No exceptions. I have two PLBs (with GPS) on board. Two lucky contestants get them attached to their life jackets. Fire extinguishers, flares, etc., all of the usual stuff. Compass, GPS, VHF, and all the electrickery you need....
- At least a case of water on board before heading out past the jetties.
Just ease into it gradually and keep challenging yourself to be more prepared each time that you go out. Exercise good judgement, be really anal retentive out maintenance on your rig, and you'll gradually gain the expreience that you need. Easy does it.
